Jul 16th, 2024, 3:02pm
Delta Sigma + Current steering DAC (Read 2950 times)
caosl_zju
Apr 10th, 2008, 7:17am
Hi, all
In a delta sigma DAC, classical implementation is Digital interpolator -->Digital DSM -->Switch Cap dac & Filter --> active filter . Now, i want to replace the Switch Cap dac with current steering dac to save area and power consumption. The question is coming, how to resolve the jiter problem? The dac level is just 9.
All comments are welcome.
Re: Delta Sigma + Current steering DAC
Reply #1 - Apr 11th, 2008, 9:47pm
I think the jitter is a common problem for the delta-sigma DAC with switch-cap dac & filter and the delta-sigma DAC with current-steering DAC. Right?
Yawei
caosl_zju
Reply #2 - Apr 13th, 2008, 12:25am
hi,Yawei
   Thanks for your reply. Switch cap implementation is a discrete time style, the final settled value is of most concern. But in a current steering DAC circuit, the full time value must be cared, the jitter will introduce the error in transform process, just in a Continuous time Sigma Delta ADC which is a hot topic in mixed signal ic design nowadays, if the feedback dac is a current steering form, the jitter will normally restrict the whole system performance. Expect more discussion.
   san.
