May 19th, 2024, 12:10am
impact on current with change in metal thickness? (Read 5321 times)
sirous black
Apr 25th, 2008, 5:31am
On changing a given metal from 2XTM to 1XTM, what is the impact on current? I understand that there is a change in resistance, and hence overall IR drop, but current benig a surface phenomena wouldnt be affected.
Correct me if my assumption is wrong.
Re: impact on current with change in metal thickne
Reply #1 - May 14th, 2008, 4:10pm
please explain with more detail what you are looking for
CMOSSolutions
Reply #2 - May 29th, 2008, 9:25am
Is this a large mixed signal SOC? For large designs the IR drop in power distribution is pretty much DC to daylight, so thinner metal will affect the IR drop. Also check the current density and EM limits for your specific process. Hints about the type of design, frequency and process info would help.
Maks
San Jose
Re: impact on current with change in metal thickness?
Reply #3 - Apr 25th, 2010, 12:26pm
sirous black wrote on Apr 25th, 2008, 5:31am:
Depending on the design of the power FET (metal resistivities, device resistance, layout shapes, metal strapping, etc.) changing metal thickness or resistance may or may not affect the total resistance and the pattern of the current flow. One needs to run simulations of the device + metals+ vias + wirebonds to understand the impact of an individual metal layer resistivity on the total Rdson value. See attached plot for an example of such simulations - the plot shows the current density distribution in the top metal layer of a three-metal-layer power MOSEFT design.
