Stefan wrote on Jun 20th, 2008, 2:23am:There are several ways how this could be avoided.
a) do a toplevel simulation from backannotation (crazy)
b) do a layout vs. schematic check
and do a functional verification of your toplevel schematic.
c) check your netlist for number of connections to each node.
In most oppinions, b is the way to go for ...
Stefan
Thanks for the quick reply.
a) is out of the question as this is a full rf-receiver.
b) A LVS match will only tell if there's a mismatch between the layout and schematic, not if the schematic is connected correctly.
I'll see what I can do with the netlist.
At the moment I am relying on mixed-mode simulations to catch any wrong polarities or mis-connecitons. But this is more to verify the interaction between the digital control and the individual blocks. My verilogAMS views are not that detailed that they catch whether a current supply bias line has been used twice.
Cheers
