Aug 15th, 2024, 9:35pm
verification of connections for large designs (Read 2298 times)
trond
Glasgow, Scotland
Jun 20th, 2008, 2:18am
Hello all,
this might be a trivial question but I was wondering how people go about checking whether there are no unintended connections in large designs.
Obviously, a "check and save" will reveal unconnected lines and also whether the signal lines have the same number of bits as the blocks their being routed to.
However, a "check and save" won't flag if I am using the same bus-bit for two blocks, ie. have signal<3> used on two different blocks by accident. Is there a way of checking whether each bit has only one connection?
Any tips on how people go about checking their top level schematic are appreciated.
Stefan
Re: verification of connections for large designs
Reply #1 - Jun 20th, 2008, 2:23am
There are several ways how this could be avoided.
a) do a toplevel simulation from backannotation (crazy)
b) do a layout vs. schematic check
  and do a functional verification of your toplevel schematic.
c) check your netlist for number of connections to each node.
In most oppinions, b is the way to go for ...
Stefan
View Profile 16731287   IP Logged
trond
Glasgow, Scotland
Reply #2 - Jun 20th, 2008, 2:33am
Stefan wrote on Jun 20th, 2008, 2:23am:
Stefan
Thanks for the quick reply.
a) is out of the question as this is a full rf-receiver.
b) A LVS match will only tell if there's a mismatch between the layout and schematic, not if the schematic is connected correctly.
I'll see what I can do with the netlist.
At the moment I am relying on mixed-mode simulations to catch any wrong polarities or mis-connecitons. But this is more to verify the interaction between the digital control and the individual blocks. My verilogAMS views are not that detailed that they catch whether a current supply bias line has been used twice.
Cheers
