May 18th, 2024, 12:42am
How to increase the standard deviation of jitter (Read 2385 times)
pkd
India
Aug 13th, 2008, 7:29pm
I have a PLL which takes a sinusoidal input and converts it to square wave with a frequency set by the control bits.
I want to perform an experiment by increasing the standard deviation of the jitter (but keeping the Gaussian behavior of jitter in tact).
How can I do that from the external control?
Thanks in advance. Smiley
-pkd
Stefan
Re: How to increase the standard deviation of jitter
Reply #1 - Aug 14th, 2008, 11:02am
Hi PKD, you should read some more literature about jitter in PLL's.
Your question does not allow to judge, which jitter of which block you want to vary. If you're just curious in checking the effect of any jitter on the output, either vary your reference frequency or change the kVCO of your VCO with a gaussian pulse.
Stefan
View Profile 16731287   IP Logged
