Jul 16th, 2024, 4:35am
gates.va and transition() (Read 14563 times)
Sep 04th, 2008, 7:12am
I was running the Verilog-A logic gates from:
http://www.designers-guide.org/VerilogAMS/functional-blocks/gates/gates.va
in a commercial simulator, and I got this warning:
   VERILOG-A PERFORMANCE WARNING:
       "gates.va", line 125: The first argument to the transition filter is a
       continuous signal, which might slow down the simulation.
       Further occurrences of this warning will be suppressed.
If I change, for example,
   V(out) <+ transition( !((V(in1) > vth) && (V(in2) > vth)) ? vh : vl, td, tt );
to
   vout = ( !((V(in1) > vth) && (V(in2) > vth))) ? vh : vl;
   V(out) <+ transition( vout, td, tt );
then I don't get the warning, and the simulation runs 40x faster!
jbdavid
Re: gates.va and transition()
Reply #1 - Sep 4th, 2008, 10:49am
you would think Ken would know better..
But maybe SOME commercial simulators figure out that the expression is results in a logical value, and some don't..
I normally only evaluate the logic output on the cross event.. not every time step -- unless I need to support spectreRF.. (and i think the transition statement itself is a problem there)
jbd
jbdavid
Reply #2 - Jan 5th, 2009, 8:29am
Hmm, spectre doesn't seem to be that clever about figuring this out. Even just reformulating the same expression as:
stops the warning. I'll file a CCR to see if we can improve it.
Dan Clement
Salt Lake City, Utah, USA
Reply #3 - Jan 25th, 2009, 9:40pm
Can you please explain why there is a speed difference in the original question?
Dan
Reply #4 - Jan 27th, 2009, 12:37pm
Dan,
No, but I didn't do any significant tests - mine was just to see if it compiled rather than giving it anything sensible to simulate.
Perhaps Geoffrey can comment - I'm sure he'll take this up with Cadence  ;)
Dan Clement
Reply #5 - Jan 28th, 2009, 6:10am
Hi Andrew,
That's cool.  I seem to keep running into speed issues when I try to use the transition and slew operators.  So if anyone can explain the right and wrong way to use these functions, I would truly appreciate more guidance.
I am a spectre user.
Dan
Reply #6 - Feb 2nd, 2009, 10:38am
I think the issue is, if you were to do
V(out) <+ transition( V(in1), td, tt);
then every time V(in1) changed even the slightest, the simulator would have to schedule a timepoint at t+td to propagate this change to the output (and further timepoints up to t+td+tt to finish the transition).
I guess the simulator sees the V(in1) in the original argument and schedules these timepoints, even at timepoints where the Boolean expression isn't changing.
Reply #7 - Feb 3rd, 2009, 9:07pm
That's a good point. Merely fixing the warning is not enough - the warning is reasonable, if that's the behaviour. We need to fix it to prevent the transition being unnecessarily triggered by what it sees as a continuous signal. I'll append this to the CCR I filed.
DmitTrix
Haifa, IL
Reply #8 - Feb 8th, 2011, 5:08am
(sorry for resurrecting an old thread, but it seems to me the appropriate place to ask...)
I've run into this warning ("The first argument to the transition filter is a continuous signal, which might slow down the simulation") while using a simple Sample-and-Hold implemented as follows:
 parameter real Vt = 0.5 from (-inf:inf);
 parameter real Td = 0    from [0:inf);
 parameter real Tr = 100p from (0:inf);
 parameter real Tf = 100p from (0:inf);
 real vout_val;
 analog begin
   @(cross(V(vclk) - Vt, 1))   vout_val = V(vin);
   V(vout) <+ transition( vout_val, Td, Tr, Tf );
Seems that Spectre refers to a real value as to a value that can change continuously (although it doesn't), and issues the warning.
I don't see any way to implement it without using a real value, or without using the "transition" filter (removing it will cause too abrupt changes at the output).
Any suggestions?
Thanx,
Dmitry.
P.S. I'm running MMSim 10.1
Reply #9 - Feb 8th, 2011, 11:24am
One question might be: does it seem to be slowing down the simulation?
naderi
Canada
Reply #10 - Feb 24th, 2011, 5:43pm
I also have the same problem. The block is basically a sample and hold. The output signal is not continuous time, despite the warning.
I am not sure about the correct method of speed test. However, it seems to me the simulation time increases specially when it is used with other blocks.
Ali
