tkhan
I have an instance of symmetric inductor and it has the option of adding a center tap. Regardless of whether there is a CT or not, the spectre view still has the 3rd terminal. When I simulate a circuit using this inductor, I get the same results with or without the CT enabled (keeping all other parameters equal). When I look at the layout pcell, there is clearly a difference between the CT and no CT layouts (i.e. the presence of the CT). When I plot the voltage on the net connected to the CT, it is the same with and without the CT enabled. Any insight? Thanks.
