Aug 14th, 2024, 5:26pm
nonlinearity of poly-poly or MIM caps (Read 4010 times)
vivkr
Oct 13th, 2008, 11:03pm
There is a small nonlinear component even in linear caps such as poly-poly or metal-metal, which is important when designing very precise analog circuitry. Typically, the nonlinearity is much less than 100 ppm/V.
Intuitively, I would expect the nonlinearity to be quadratic, i.e. C(V) = C0 + C2(V^2), as I would imagine that the polarity of the applied voltage has no (or very little) influence on the nonlinearity, and only the magnitude matters. However, I often see a linear term here, and
C(V) = C0 + C1(V) + C2(V^2)
The linear term appears to be not insignificant. Why would there be a linear term at all?
Vivek
rf-design
Reiner Franke
Re: nonlinearity of poly-poly or MIM caps
Reply #1 - Oct 14th, 2008, 1:32am
I assume that the linear term is steeming from a space charge effect similar to a MOS cap. Typical linear caps in submicron are obtained by canceling two opposite nonlinear terms. It could also be a extraction artifact where the linear term was not set to zero in a more general extraction routine.
http://www.ece.nus.edu.sg/stfpage/elelimf/pub(updated_20Nov2004)/Kim%20VLSI%2004...
HdrChopper
Reply #2 - Oct 14th, 2008, 7:14pm
Hi Vivek,
I'm just guessing, but since usually the parasitics on the cap bottom plate is different from the one on the upper plate  I would tend to think the sign  of the applied voltage might be important. If that was the case then it makes some sense to have a non-insignificant linear term in the capacitor model as a function of the applied voltage...
Tosei
Keep it simple
vivkr
Reply #3 - Oct 21st, 2008, 10:57pm
Thanks to everyone for the very useful answers and references. Now things seem a bit clearer.
Vivek
