Oct 10th, 2026, 7:08pm
need vhdl code (Read 3099 times)
nave4u
need vhdl code
Nov 04th, 2008, 1:52am
hi every one
i got problem in writing a code for small architecture can any one help me out...the problem is
i have one 4-bit registe as one of the input to a 2:1 mux and other input is bit '1' and i have a selection line which will select either of input....if selection line is ' 1' then the output of mux is lsb of 4-bit regester and if the selection line is '0' then the output of the mux is '1' which is second input of the mux.....and for every clock cycle i need to shift the 4-bit register to the right and it should be done in 3 cycle till all the bits in the regester get selected...
plzzzz help me out from this problem as soon as possible....
