May 19th, 2024, 9:19am
64 bit cadence, icfb (Read 10231 times)
wave
Nov 11th, 2008, 10:56am
Hello - I believe we have a 64b version of Cadence.
How do I verify and launch icfb?
Perhaps:
icfb -64 &
thanks
Wave
bernd
Munich/Germany
Re: 64 bit cadence, icfb
Reply #1 - Nov 17th, 2008, 8:17am
I would recommend to set the UNIX environment 'CDS_AUTO_64BIT' variable to
CDS_AUTO_64BIT=EXCLUDE:si.exe
This will tell Cadence DFII to use all existing 64 bit executables
except CDL-in/out.
There is no 'icfb -64'.
* bernd
Just another lonesome cad guy
Reply #2 - Jan 2nd, 2009, 11:55pm
The focus on 64 bit support has always been to provide 64 bit executables where there is a capacity need. There is no benefit in running 64 bit apps otherwise (it just increases your memory consumption!)
So support has (so far) been limited to layout, stream in/out, physical verification, and simulation. That means for DFII, the "layout" executable is available in 64 bit mode.
In the upcoming IC614 release, Cadence should be providing 64-bit support across Virtuoso, as this is becoming increasingly necessary.
