May 16th, 2024, 5:26pm
The cdd parameter in BSIM3v3 model (Read 2489 times)
Nov 20th, 2008, 2:20am
Hi Guys,
The parameter cdd is defined as dQd_dVd (Intrinsic part of Cdd) (alias=lx33). Now I want to measure the parasitic capacitance at the drain of one MOS transistor. The simulation bench is shown in this post. A voltage source is applied to the drain of one NMOS transistor. A DC analysis is run. The parameter cdd is about 29 fF in the printed DC operating points of that NMOS. An AC analysis is run, too. Then I calculate the total parasitic capacitance at the drain based on the small signal impedance. The result is about 58 fF. The detailed formula is I(V0)/V(V0)=omega * Cd. What's wrong with my analysis?
Thank you in advance
Yawei
Re: The cdd parameter in BSIM3v3 model
Reply #1 - Nov 20th, 2008, 10:12am
Cdd I think only includes the channel capacitance -- no diode/depletion cap from B-D junction and no overlap capacitance.
