May 11th, 2024, 8:09pm
What's the relation between dBc/Hz and dBc in E5052A? (Read 5938 times)
Ryan Cheung
Nov 27th, 2008, 10:34pm
Hi everyone,
When measure the spurs of a PLL using E5052A, there are 2 units could be selected for spur (dBc and dBc/Hz) in phase noise measurement. And if we use dBc as the spur level unit, we found it is much closed to the spectrum plot measured by E5052A. What's the difference between them?
Ryan
Re: What's the relation between dBc/Hz and dBc in E5052A?
Reply #1 - Nov 27th, 2008, 10:54pm
Ryan Cheung wrote on Nov 27th, 2008, 10:34pm:
If you mean Agilent Signal Source Analyzer, I recommend you to post to Agilent Discussion Forum.
Agilent Signal Analyzer (RF & Microwave) Forum
http://forums.tm.agilent.com/phpBB2/index.php?c=15
Ryan Cheung
Reply #2 - Nov 28th, 2008, 6:34am
thanks! Cheesy
smlogan
Boston, MA
Reply #3 - Apr 16th, 2009, 1:07pm
Hi everyone,
Ryan
Hi Ryan,
I have the predecessor to the 5052A, a 4352. In that instrument, it would report integrated noise in "dBc". Hence, my guess is it is reporting either the SSB value of the spur in dBc/Hz or the integrated value of the spur related to the carrier as dBc.
Just my guess...
Shawn
Shawn
