Or you can use the cell-based Verilog-AMS netlister to do this. If you use Tools->AMS->Netlist in the CIW, you can specify a cellView. It will create the netlist within the cellView directory, so you can find it there...
This doesn't need any switch/stop view setup (because it only netlists a single cellView), but if you have primitive devices in the schematic, it would need ams simInfo in the CDF (this isn't needed for blocks though).
