Jul 3rd, 2025, 3:49am
schematic to Verilog-A (Read 7883 times)
rajdeep
UK
Dec 09th, 2008, 3:35am
Is there a way to convert a schematic into a structural Verilog-A code.
Say, I connect 3 blocks A, B and C in some way using Cadence Schematic Editor.
Now is it possible to translate this scheamtic into an equivalent verilog-A view?
The inbuilt view translator doesnt work!
One easy way cud be translatng the spectre netlist into an equivalent verilog-A netlist using
soem scriptng, but the script is failing at time...so in the lookout for a robust code or available
tool for this! Otherwise, it is abs nightmare to wire those big netlists manually!
Rajdeep
Re: schematic to Verilog-A
Reply #1 - Dec 9th, 2008, 4:02am
You can do such netlisting by using NC-Verilog or Verilog-XL integration in ADE.
This means netlisting by netlister for Verilog-D.
But you have to force netlister to stop before transistor level.
Here you have to specify any virtual stop view for lowest blocks which include transistor, resistor, etc.
« Last Edit: Dec 9th, 2008, 6:29am by pancho_hideboo »
Reply #2 - Jan 2nd, 2009, 11:42pm
Or you can use the cell-based Verilog-AMS netlister to do this. If you use Tools->AMS->Netlist in the CIW, you can specify a cellView. It will create the netlist within the cellView directory, so you can find it there...
This doesn't need any switch/stop view setup (because it only netlists a single cellView), but if you have primitive devices in the schematic, it would need ams simInfo in the CDF (this isn't needed for blocks though).
