Aug 19th, 2024, 6:25pm
Improvements in a basic opamp circuit (Read 1967 times)
Analog_Rex
Dec 13th, 2008, 12:45am
Hi...
      I have a basic circuit with an opamp using a simple negative feedback configuration with two resistors. When i tested the circuit, I noticed that for a 1V input it saturates on the positive output. I would want to improve this basic opamp circuit in a way that it does not saturate even when the input is 1mV.
Can somebody help me with this?
Thank you
Rex
buddypoor
Bremen, Germany
Re: Improvements in a basic opamp circuit
Reply #1 - Dec 13th, 2008, 1:40am
Analog_Rex wrote on Dec 13th, 2008, 12:45am:
Hi...
Thank you
Rex
It would be very helpful if you could give us the gain of your opamp stage.
raja.cedt
Reply #2 - Dec 13th, 2008, 1:46am
hi,
   even i want to know what is gian in closed loop as well as open loop.it will impact u r SAT level.one more thing did u bias your opamp non-inverting terminal.It would be great help if u rgive the circuit.
Thank you.
