Aug 15th, 2024, 11:13am
Efficient way to convert s-param model of transformers to lumped circuit (Read 2576 times)
schehrazi
University of CA, LA
Dec 17th, 2008, 3:02pm
Hi All,
There are a few softwares that give out lumped models for s-parameters of an inductor over a range of frequencies.
Do you know of a way to do the same thing for a transformer?
Thank you.
jbdavid
Re: Efficient way to convert s-param model of transformers to lumped circuit
Reply #1 - Dec 18th, 2008, 8:00pm
Run Spectre "sp" analysis?
jbdavid
Reply #2 - Dec 19th, 2008, 12:10am
schehrazi wrote on Dec 17th, 2008, 3:02pm:
Create equivalent model of target transformer and determine parameters by using optimizer with SP-analysis in Agilent ADS.
Or use Broadband SPICE Model Generator in Agilent ADS.
I recommend to use former method.
« Last Edit: Dec 19th, 2008, 7:50am by pancho_hideboo »
