Rodrigo Matias wrote on Jan 3rd, 2009, 3:42pm:I'm having some spurs on the VCO. They appear as simmetric at +/-9.6kHz from the fundamental frequency (172MHz).
Rodrigo Matias wrote on Jan 3rd, 2009, 3:42pm:I also turned off the PLL and let the VCO run freely and the kept appearing.
Rodrigo Matias wrote on Jan 3rd, 2009, 3:42pm:3) The purpose is to decode GMSK data with 9k6bitrate and M=0.5 (this means I have 2k4 and 4k8 sinusoids on my data signal).
Rodrigo Matias wrote on Jan 3rd, 2009, 3:42pm: I tried to reduce pll feeback loop filter from 2.5kHz to 1.5kHz and nothing happened.
Is there any devices which is related to modulation ?
Your spurious is just 9.6kHz and symmetrical, so there must be 9.6kHz noise source in your board. Check power supply line of VCO and PLL.
Try to broaden bandwidth although it must interrupt demodulation.
Rodrigo Matias wrote on Jan 3rd, 2009, 3:42pm:The first IF on the circuit is at 10.7MHz and they appear there as +/-3.1kHz
I can't understand what you mean.
