May 3rd, 2024, 7:34pm
Active inductor simulation (Read 4649 times)
noppp
Jan 13th, 2009, 1:10am
I want to ask any one has a tutorial for Active Inductor Simulation using Cadence Spectre simulator.
buddypoor
Bremen, Germany
Re: Active inductor simulation
Reply #1 - Jan 13th, 2009, 2:35am
noppp wrote on Jan 13th, 2009, 1:10am:
What are you mostly interested in ? Tutorial for active inductor replacement or simulation of the corresponding circuit ?
noppp
Reply #2 - Jan 13th, 2009, 5:39am
Thanks for reply,
Really, I just started studing Active Inductors cicuit and its applications.
So, any tutorial will be helpfull for me.
If you have any, please send me or upload.
thanks in advance.
buddypoor
Bremen, Germany
Reply #3 - Jan 13th, 2009, 7:20am
noppp wrote on Jan 13th, 2009, 5:39am:
At the moment, I have no tutorial (software) at hand, however, it should not be a problem for you to find some relevant articles/papers/tutorials via google, since active inductor design is one of the most favorite design method for active filters.
Search for GIC (generalized impedance converter) or simply for "active inductor". The GIC requires two matched opamps.
If lossy inductors are allowed you can use the NIC (neg. impedance converter) with only one opamp.
If you have some specific questions regarding active inductor application, donīt hesitate to ask again - however, there is one thing you should keep in mind: With 2 opamps you only can simulate an active inductor which is grounded !!!
LvW
oermens
Reply #4 - Jan 13th, 2009, 12:21pm
