May 20th, 2024, 9:04am
Need lower power replacement for atf54143 (Read 2169 times)
dhnobles
Feb 05th, 2009, 7:47am
Is anyone aware of a direct (or similar) replacement for an Agilent ATF54143 PHEMT ?
I am developing a Low Noise Amp (LNA) and although this component meets my noise requirements it is a bit of a power hog (60mA) in my application. I am looking to at least half the power consumption but any component that reduces the power is welcome.
thanks!
Re: Need lower power replacement for atf54143
Reply #1 - Feb 6th, 2009, 7:41pm
dhnobles wrote on Feb 5th, 2009, 7:47am:
*** Avago ATF-54143 ***
     SOT-343 package
     NF=0.55dB, Ga=17.4dB at 3V, 60mA (2GHz)
     P1dB=20.4dBm, and OIP3=36dBm at 3V, 60mA (2GHz)
What is your requirement ?
Do you need same P1dB and OIP3 as ATF-54143 ?
What frequency band do you use ? Upto 2GHz ? Or around 2GHz ?
« Last Edit: Feb 7th, 2009, 4:55am by pancho_hideboo »
