May 20th, 2024, 8:04pm
About BSIM3v3 small-signal parameters (Read 3061 times)
DoYouLinux
Feb 16th, 2009, 3:36am
Dear all,
I have a  question to ask about BSIM model. Since now I am using a BSIM3.3 0.18-um CMOS model in my work (Cadence, Spectre) and I am wondering about how to figure out the total parasitic capacitances of a transistor. In PSPICE, after I ran a simulation and click on the Probe window to see the output file, I can see a list of small-signal parameters saying that, for example, Cgs = 10 fF (for intrinsic), Cgsov = 20 fF (for overlap capacitance), etc.
However, for BSIM3.3 and for Spectre simulator, I receive a set of small-signal parameters after running a simulation, for example, as shown in the attached picture. For these parameters, for the capacitances, I don't know how to calculate the total intrinsic and extrinsic capacitances since they are separated into several capacitances. Would you mind to explain me a little bit about this and in case that I would like study more, is it possible to recommend me some books or some documents explaining about this ?
Thank you very much,
DYL Smiley
Re: About BSIM3v3 small-signal parameters
Reply #1 - Feb 16th, 2009, 4:10am
This has come up numerous times before. I suggest trying the "Search" facility of the forum. I just did that and found:
http://www.designers-guide.org/Forum/YaBB.pl?num=1087411058/1#1
http://www.designers-guide.org/Forum/YaBB.pl?num=1077279932/1#1
http://www.designers-guide.org/Forum/YaBB.pl?num=1053460340/1#1
there are others - these are just some of my own responses...
DoYouLinux
Reply #2 - Feb 16th, 2009, 4:14am
Oh, Thank you very much, Andrew. Yes, you were right, I forgot searching in the forum before.
DYL
