May 18th, 2024, 8:20am
"Coupling" and "De-coupling" extraction, which is more accurate? (Read 3067 times)
frank007
Feb 27th, 2009, 6:12pm
I did two Assura RCX extractions with "coupling" and "de-coupling" extraction. The post-layout simulation gives pretty different result. The "de-coupling" one works fine, but not the "coupling" one. So which extraction is more accurate? Thanks.
Frank Wiedmann
Munich, Germany
Re: "Coupling" and "De-coupling" extraction, which is more accurate?
Reply #1 - Feb 28th, 2009, 5:10am
deepak
Reply #2 - Jul 30th, 2009, 4:03am
you should use coupled one.. it is more accurate as it derives the parasitics between two nets.....
in decoupling mode.... it get thee parasitics between nets and decoupled that to ground....
