Sep 17th, 2024, 7:29pm
How to implement a new analysis in spectre? (Read 7108 times)
MadMood4RF
France
Mar 05th, 2009, 7:33am
I would like to implement a new analysis in spectre.
In this analysis, several transient analysis are launched. Output data are processed at the end of every transient analysis.
thank you in advance.
Re: How to implement a new analysis in spectre?
Reply #1 - Mar 5th, 2009, 9:46pm
Your question is a bit vague. Are you trying to do this in spectre standalone (if so, you could use spectreMDL)? Or are you trying to do this in ADE (if so, you could have an include file specifying multiple tran analyses, and then calculator expressions referring to the particular transient result in the outputs pane in ADE)? Or are you trying to do this with OCEAN?
What kind of measurements - is one tran dependent on the results of another (i.e. why do you need to have the results done after each tran)? Can it be done with an OCEAN script with a loop?
As you can see, I have lots of questions, because it wasn't clear what your objective really was.
MadMood4RF
France
Reply #2 - Mar 8th, 2009, 5:17am
Thank you Andrew.
I will explain my idea.
I would like to obtain the complex gain of an amplifier using a large-signal analysis.
I have to vary the amplitude of a sinusoidal input voltage for a fixed frequency.
But, I do not need to do the simulations on an interval of input voltages.
I just need to estimate iteratively (and with some precision) the value of the input signal amplitude that produced a given gain(identified by a magnitude value).
In addition to this analysis that I intend to do in OCEAN scripting, I would like to know how to display this new analysis in the menu of "cadence : virtuoso analog design environment" with all standard analyses.
Thank you for your help.
Reply #3 - Mar 8th, 2009, 8:20am
I can't understand meanings of your questions all over.
If you want someone to understand your questions,
you have to describe your questions regarding situation and condition in detail and correctly using industrial standard terminologies.
MadMood4RF wrote on Mar 8th, 2009, 5:17am:
What do you mean by "complex" ?
Do you mean complex number gain which have magnitude and phase ?
What do you mean ?
I can't understand your thinking.
Gain below compression points is constant regardless of input signal level.
Do you want to evaluate output level above gain compression point ?
It is not new analysis at all.
Just use PSS analysis of Cadence Spectre.
If you insist on using Transient Analysis, use parametric sweep analysis with transient analysis.
« Last Edit: Mar 8th, 2009, 3:29pm by pancho_hideboo »
MadMood4RF
France
Reply #4 - Mar 8th, 2009, 3:50pm
-English is my third foreign language, so sorry if it has a negative impact on "industrial standard terminologies" I use
-yes, I mean gain which have magnitude and phase.
-yes, I obviously want to evaluate output level above gain compression point.
-This gain is calculated according to the value of the input signal magnitude.
Since we just want to know the magnitude that produces a given gain we do not need to sweep overall the interval of the input signal magnitude.
-I know that it is not new at all, but I want to begin by using the transient analysis before attempting the PSS analysis which is new for me.
-The parametric sweep analysis does not allow me to re-evaluate the parameters of the next simulation from the previous; It is essential to converge towards the solution that gives the sought magnitude.
-I also would like to know how to display this new analysis in the menu of "cadence : virtuoso analog design environment" with all standard analyses.
Reply #5 - Mar 8th, 2009, 7:50pm
MadMood4RF wrote on Mar 8th, 2009, 3:50pm:
Use Optimizer with Transient Analysis. Or use Neo Circuit.
Your analysis shouldn't be listed up in standard analyses. It must be listed as another menu since it is ocean script.
Do you have enough knowledge of Skill langage and Cadence DFII ?
Expression of "implement a new analysis in spectre" is not correct for your case.
Expression of "implement or add a new analysis in ADE" is correct for your case.
MadMood4RF
France
Reply #6 - Mar 9th, 2009, 8:26am
I realy do not want to use optimizer. I leave NEO as a last resort because I have already my ocean script and I just want to know how to add a new analysis in ADE.
Ok, so How should we do so that it can be listed in the menu?
SKILL is a lisp-like language. I've seen far more frightening language. If it's the better way to achieve my task, I can spend the necessary time to do it using "SKILL".
Reply #7 - Mar 10th, 2009, 1:09am
Your question is not about simulator. Of course there is no relation to RF simulator at all.
You have to study what your questions are before you post questions.
Due to your poor descriptions, we couldn't understand what your questions really were.
Your requests are:
You have Ocean Script for optimization with transient analysis.
Here you want to launch this Ocean Script from menu list of ADE.
It is not an implementation of a new analysis in Cadence Spectre at all.
MadMood4RF wrote on Mar 9th, 2009, 8:26am:
An optimizer I mean is not Neo Circuit.
There is an optimizer in Cadence ADE although its perfomance is fairly poor.
Not so easy. It is not only task of adding menu. There are many tasks required.
Generally this is a charged service which Cadence offer.
First you have to have deep knowledge about Cadence DFII.
See the followings.
Virtuoso Analog Design Environment SKILL Language Reference
SKILL Language User Guide
« Last Edit: Mar 10th, 2009, 2:27am by pancho_hideboo »
MadMood4RF
France
Reply #8 - Mar 10th, 2009, 3:44am
Quote:
Not so easy. It is not only task of adding menu. There are many tasks required. Generally this is a charged service which Cadence offer.
it is precisely these tasks I wish to know to implement them no more. Even it is a charged service which Cadence offer, I thought it was possible to get help on this forum.
My question remains!
Reply #9 - Mar 10th, 2009, 3:59am
MadMood4RF wrote on Mar 10th, 2009, 3:44am:
I thought it was possible to get help on this forum. My question remains!
Again read the followings.
I don't think there is anyone kind and patient enough to show troublesome procedures step by step.
