May 17th, 2024, 11:43am
help with characterization of thin film semiconductor devices (Read 1834 times)
bhavi
Mar 19th, 2009, 10:14pm
I am currently working on some Barium Strontium Titanate and Aluminum Oxide thin films having n-Silicon substrate as the substrate. I have done a voltage sweep from +20V to -20V on the devices with the frequency constant for each sweep. The frequencies that I used are 1 kHz, 1 MHz and 10 MHz. Can anyone tell me how to find out the behavior of the devices in general from the values obtained from the voltage sweep.
Thanks in Advance.
Bhavi
