May 22nd, 2024, 11:32pm
QPSS taking very long time to converge (Read 73 times)
Sandeep Mallya
Mar 25th, 2009, 2:43pm
Hi.
I am simulating I/Q mixer using QPSS. QPSS is going through many stabilisation iterations (about 60) with conversion norm changing very little between these iterations. Once Newton iterations start, QPSS converges with 2 iterations.
But, due to the large number of stabilisation iterations, QPSS takes a very long time to complete. Can anyone point out why QPSS could be going through so many stabilisation iterations?
Murat H. Eskiyerli
Ex Member
Re: QPSS taking very long time to converge
Reply #1 - Mar 26th, 2009, 4:00am
Could you try using flexible balance with setting the oversampling ratio to higher than 1, maybe 3. If your mixer has a feedback loop, it might slow down QPSS type simulations quite a lot, I found.
  IP Logged
Sandeep Mallya
Reply #2 - Mar 26th, 2009, 4:10am
Hi Murat,
Thanks for your reply.
I have tried using flexible balance. But I don't get reliable results. This may be because my mixer is too non-linear for flexible balance to give good results.
Today I tried setting the stabcycles parameter. With this I was able to limit the number of stabilisation cycles and reduce the total simulation time for QPSS.
with regards,
Sandeep
