And you should never use oscillator mode for a driven circuit. This can lead to convergence problems as it tries to solve for an unknown that isn't unknown...
ADE will find the frequencies of sources in your schematic, and can use that to figure out the fundamental frequency. Also, spectre will check sources for consistency with your specified fundamental, or can figure out the fundamental itself for PSS when autofund=yes is specified.
