Jul 17th, 2024, 12:52pm
why do we use active filter? (Read 7162 times)
liletian
MD
Apr 30th, 2009, 7:34pm
 Hi Guys
 what is the advantages of active filter? The only advantage I can think is active filter can give you, is there any other reasons for it?
Re: why do we use active filter?
Reply #1 - Apr 30th, 2009, 7:42pm
liletian wrote on Apr 30th, 2009, 7:34pm:
It doesn't require inductor.
I can't understand what you mean.
liletian
MD
Reply #2 - Apr 30th, 2009, 7:51pm
pancho_hideboo wrote on Apr 30th, 2009, 7:42pm:
so two advantages:
1. high gain
2. no need inductor
disadvantages:
consume power
right?
So the question is in PLL, active filter is used, the only reason is due to its high gain?
Reply #3 - Apr 30th, 2009, 9:47pm
Liletan,
You might also want to take a look at,
  http://en.wikipedia.org/wiki/Active_filter
Not sure if high gain is helpful for a PLL loop filter,
wouldn't increase the kvco and the phase noise?
Reply #4 - Apr 30th, 2009, 10:53pm
liletian wrote on Apr 30th, 2009, 7:51pm:
Loop filter for PLL often requires very large capacitors and resistors.
If you use on-chip loop filter, such very large capacitors and resistors occupy large area.
If you use active filter, you can reduce capacitors and resistors, although there are many problems in PLL.
raja.cedt
Reply #5 - Apr 30th, 2009, 11:58pm
hi
  i think it is debatable question because-now a days most of the plls are having tough jitter specification, so in that case simple active filter wont help much, but there are another class  called tracking bandwidth plls they will utilize active components in different passion to get very good jitter specification .At the same time active filter may not reduce much area because no there is no inductor (forget about LC vco).
Rajasekhar.
Reply #6 - May 2nd, 2009, 7:51am
 Hi Guys
Liletian,
What's your application? Perhaps we can explore the topic deeply only if we know your application.
liletian
MD
Reply #7 - May 2nd, 2009, 12:08pm
ywguo wrote on May 2nd, 2009, 7:51am:
 Hi Guys
Liletian,
 I am thinking to use it in my PLL, but I did not see any advantages over normal RC filter yet, any suggestions?
raja.cedt
Reply #8 - May 4th, 2009, 7:01am
hi,
  designers will use active filter in special cases like
1.In tracking bandwidth plls
2.To reduce filter cap size
3.To reduce impact of 1/f noise on overall phase noise
But remember all the above has to apply very carefully otherwise directly they will impact phase noise as well as jitter.
Hope this is clear,
Rajasekhar.
