Aug 16th, 2024, 4:23pm
Transferred impedence filter with passive mixer (Read 4961 times)
macg84
May 06th, 2009, 3:21am
Hallo at all,
In attached there is the schematic, the circuit should be a filter where the corner frequency are Flo-Flc and Flo+flc (Flo= frequency of local oscillator, Flc= resonant frequency 1/2*3.1415*(LC)^1/2). This filter doesn't work and i don't know why.
Is there some people that can help me with some  advice?
Thank you very much
RFICDUDE
Re: Transferred impedence filter with passive mixer
Reply #1 - May 6th, 2009, 7:22am
What nodes do you consider to be your outputs?
aaron_do
Reply #2 - May 6th, 2009, 7:53am
A few comments apart from the missing output nodes pointed out by RFICDUDE.
1. Your ideal_balun doesn't seem to be connected properly. I think the center-tap of the output coil should be grounded.
2. I'm not sure but you seem to have you LO signals connected wrongly. One is going from 0 to 3 and the other from 3 to 0. Also one is connected backwards. So overall, one is swinging from 0.4 to 3.4 while the other swings from -2.6 to 0.4. Correct me if i'm wrong there...
3. How is it supposed to work anyway?
cheers,
Aaron
RFICDUDE
Reply #3 - May 6th, 2009, 9:29am
I don't think the center tap connection matters, but it does matter that the RF input appears to be common-mode. Both ports appear to be in phase, so there is no differential signal on either side of the balun.
macg84
Reply #4 - May 6th, 2009, 9:49am
Tahnks for your attentions. I atteched a new schematic with outputs node. I think but i am not sure that the balun is right, because i look it in the Designer's Guide of Ken Kundert "Measuring S-Parameters of a Differential Mixer" infact at page 3 figure 3 the ideal balun has 2 input and two output, and the center-tap of the input coil is grounded. So I assumed that the central tap of the input coil is inherently grounded.
Do you think it is right?
The vpulse work right, because the switches have to work in alternate way.
I read thet the mixer can have this behavior in a patent.
aaron_do
Reply #5 - May 7th, 2009, 12:48am
if you zoom in to your ideal balun I think you will see something like what I have attached below. The output center-tap is the bottom left pin so i think it should be grounded or at least left open-circuit.
As for the LO signals I still think they are wrong. Try plotting net47 and net50 and see if you get the right signals.
Also, why have you changed your inputs to current sources? I'm still curious about how you expect the filter to work... is it supposed to be a mixer too?
cheers,
Aaron
macg84
Reply #6 - May 7th, 2009, 1:54am
Probably your considerations on balun are correct, thanks. I checked again  the LO signal, but i think that they are corrects. I put a current source, so use a PAC analyses to see what happens to the output current around the interest frequency. Outgoing I put another mixer.
Now try again the simulations, and then I'll tell you the result, if you interested.
Best regards
Mac
