macg84
Probably your considerations on balun are correct, thanks. I checked again the LO signal, but i think that they are corrects. I put a current source, so use a PAC analyses to see what happens to the output current around the interest frequency. Outgoing I put another mixer. Now try again the simulations, and then I'll tell you the result, if you interested.
Best regards Mac
