May 4th, 2024, 11:13am
Jitter and phase noise conversion? (Read 1850 times)
liletian
MD
May 09th, 2009, 7:27pm
 Hi guys
 I found a jitter and phase noise conversion equation from Page 146, book "The Design of Low Noise Oscillators", Jitter=sqrt(1/f).(delta_omega/Omega_center).10^(L(delta)omega)/20).
So for a center frequency of 2GHz, phase noise is 100dBc/Hz at 1MHz, the jitter will be sqrt(1/2e9)*(1e6/2e9)*10^(100/20)=0.11ps jitter, am I right?
 Or there has some other ways to do this conversion. Thank you for your help.
rfmems
Re: Jitter and phase noise conversion?
Reply #1 - May 10th, 2009, 2:54am
Hi liletian,
that is only true if your osc has only white noise and the pahse noise is exactly -20db/dec.
