May 3rd, 2024, 11:18am
Creating new symbol view for d_ff cell (Read 800 times)
santo
May 12th, 2009, 10:47am
I am a new member to this site, so firstly hello to everyone.
I have a very simple question to start with. (I apologise if this is not in the corrrect area of the forum).
I am creating a replica of the 'ahdlLib' 'd_ff' cell. The only difference is that I am adding an asynchronous reset. I have modified both the veriloga code and the symbol view to have this reset pin. However, everytime I 'check and save' the symbol view in Cadence virtuoso, there is a cross view check warning, stating that the view in the symbol is not found in the veriloga code. The simple testbench I have does not operate due to this warning.
I am pretty sure the verlioga code is correct, so is there some thing else that I could be missing here? Do I need to do any sort of compliation of the symbol ar anything like that?
Thanks in advance to anyone who offers assistance.
Re: Creating new symbol view for d_ff cell
Reply #1 - Jul 10th, 2009, 8:42am
If you can post a picture of your modified symbol, the modified verilogA code, and also what the exact errors you get are, that would help identify what the problem actually is.
santo
Reply #2 - Jul 13th, 2009, 8:42am
Andrew,
Thank you very much for your reply.
I have managed to fix the problem ...
There appeared to be something funny going on when copying existing cell views, e.g. the symbol view.  I found that if I started completely from scratch, i.e from a new cell with nothing more than the verilogA and then created a symbol view myself (rather than copying it from somewhere else), then the problem disappeared.
Thanks again!!
