Apr 28th, 2024, 8:45pm
invoking a perl script from ncverilog? (Read 5430 times)
joel
May 12th, 2009, 3:49pm
Hi All,
 My simulation needs to periodically regenerate its stimulus file based on current simulation conditions.  I have a perl script that generates the stimulus file based on a few parameters.  Is there a simple way to invoke a perl script from an ncverilog simulation and suspend the simulation until the perl script completes?  e.g.
always #10000
 begin
   $system("create_stim_file.pl");
   $readmemh( "stim_file.dat", stim_data);
I've glanced at the PLI and VPI docs, but it seems overkill and very complex for my goal.
  -Joel
joel
Re: invoking a perl script from ncverilog?
Reply #1 - Jun 1st, 2009, 12:17pm
Hi All,
 I guess I'm the only one doing this!  But just in case anyone else is interested, here is what the Cadence AE said.
Bracketing the $system call with $display statements will define its location in the event queue.  So if you put this in your primary clock loop:
  $display("about to...");
  $display("done...");
and make sure to stop your clock oscillator or whatever time-progression mechanism your sim uses while the three lines are being executed.
 Cheers,
 /jd
