Aug 16th, 2024, 12:28pm
Difference amplifier with a difference. (Read 946 times)
Riotpack
Jun 16th, 2009, 11:04pm
I am trying to design a circuit but one small aspect is holding me back.
I have two signals, we will call them A and B.
I want signal A to always appear at the output
I want signal B to be subtracted from signal A if they are common
But what I dont want is signal B at the output. That sensor is there to pickup vibration and cannot be at the output for instance if it raises to a higher peak to peak voltage or has different information then sensor A.
So it is like a difference amp, except one input is there for subtraction only.
Signal A has varying DC offset as it is a Load Cell, it is the superimposed AC signal due to vibrations I am looking at.
How is this achieved, I have been thinking about it for an hour now.
Thank you for any suggestions.
