raja.cedt
hi, start your design with some fixed vov and vdsat (typically they will be 50mv,150mv), based on this values you allocate vds of every transistor. From the given BW spec find how much gm you want and with this gm find how much gds you want for the differential gain....So with the above design strategy you will some slew rate, from your spec i don't see any requirement to find slew rate here...
Thanks, Rajasekhar.
