Apr 29th, 2024, 10:16pm
PMOS and NMOS temperature coefficient (Read 5273 times)
cmos.analogvala
India
Jul 16th, 2009, 12:10pm
I found in more than one technology that PMOS has positive temperature coefficient(IDS increases with temperature) whereas NMOS has negative temperature coefficient (IDS decreaes with temperature).
Why so ? Any fundamental reason or just fabrication effect ?
-CA
raja.cedt
Re: PMOS and NMOS temperature coefficient
Reply #1 - Jul 18th, 2009, 1:10am
i don't think so..have you used same bias in both cases?
cmos.analogvala
India
Reply #2 - Jul 21st, 2009, 12:50pm
Yes same bias voltage in both the case VGS=VDS=Vdd/2 ...The transistor is biased in saturation region ...I found it in 180nm and 90nm technologies .. I am using foundry specified model files ..
by fast i mean dc drain current increases ...i have not looked at transient results ..
The point is that it is well known that mobility degrades with temperature ..but |vt| decreases with temperature .. mobility coefficient is T^(3/2) hence mobility degrades much rapidly that |vt | decrease ..... but the results are DSm technologies are astonishing ..
Any Clue ?
-CA
