Jul 2nd, 2025, 12:53am
Ptomely-Matlab Interface (Read 2740 times)
memomemomemo
Aug 08th, 2009, 6:45pm
Hi !
I am modeling a high frequency phased array in Ptomely.
However I have no idea how to model the antenna array.
Should I model the "antenna array+channel" in the matlab?
After that, I wonder if Ptomely will allow me put a matlab black box inside the system.
What is the interface between ADS and Matlab? I know matlab codes can give an output text for Ptomely to use for modulation purposes..
Or should I try option 2? Designing the whole system in Simulink using baseband envelope? then modeling the channel and integrating it in the system may be simply, but I can't replace the circuits in transceiver instead of using behavioral models.
pancho_hideboo! I know you have a big depth of knowledge. Would you be able to help me with this problem? I appreciate your help!
Wishing you all a nice weekend!
Mehmet
Sumit Adhikari
Re:  Ptomely-Matlab Interface
Reply #1 - Aug 14th, 2009, 1:49am
Berkeley Ptolemy has a matlab interface. Please search Matlab in right pane of your Ptolemy.
Sumit
Reply #2 - Nov 3rd, 2009, 4:23am
memomemomemo wrote on Aug 8th, 2009, 6:45pm:
I recommend you to use MATLAB.
Yes, you can do.
Ability of importing of MATLAB functions are provided as standard menu in Agilent ADS.
http://edocs.soco.agilent.com/display/ads2009/MATLAB+Cosimulation+Introduction
MATLAB is different from Simulink.
Simulink is alternative solution for Agilent Ptolemy. But there is no alternative solution for MATLAB in Agilent ADS.
However I recommend you to use Simulink not Ptolemy since we can't expect any progress in Agilent Ptolemy any more.
Only one benefit of Ptolemy is it's ability of post processing, here you can use same usemodel for Analog/RF domain.
But Simulink is superior than Ptolemy regarding performance as simulator.
I can't understand what you mean.
There is no difference between Simulink simulation and Ptolemy simulation.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1238242506/1#1
« Last Edit: Nov 3rd, 2009, 6:41am by pancho_hideboo »
memomemomemo
Reply #3 - Nov 3rd, 2009, 11:31pm
Thank you pancho,
I am using simulink to model the system.
I have some other questions. I am having difficult since I am new in simulink.  I have a lot of real circuit data (s2p file for LNA, mixer , PA etc) and I need to model this radar system with these files.
So as you guess I am using the RF blockset.
A guy in a company told me that I can not use simulink at 60GHz or 77GHz because of the sampling. Why is it? Is it because at baseband, that means a lot of samples? I had no difficulty to do it so far but I have doubts that I am doing something wrong.
Such as I started putting a channel measured at 60GHz spectrum as a RF block. I am attaching the jpeg file which will give you an idea.
So is it right modeling? How come can use a rf blockset at passband?
Or is it possible to integrate the circuit s2p models like this in the model?
thanks a lot!
:exclamation
Reply #4 - Nov 4th, 2009, 7:28am
Create another thread.
memomemomemo wrote on Nov 3rd, 2009, 11:31pm:
Basically there is no difference between Ptolemy and Simulink if you can understand concept of equivalent lowpass model for RF bandpass system very correctly.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1245687123
Compared to Ptolemy, Simulink have "Frame-based sampling mode" in addition to "Sample-based sampling mode".
On the other hand, Ptolemy have only "Sample-based sampling mode".
Why is it?
If your system is not bandpass system,
it is almost impossible to simulate since we can't use equivalent lowpass model or equivalent baseband model.
This is true for both Ptolemy and Simulink.
I can't understand what you mean. Which do you mean "true baseband" or "equivalent baseband" ?
Show me "signal attributes" of each node, e.g. signal type, sampling rate, etc. You can show them easily in Simulink.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1233929450
Describe with correct terminologies.
Equivalent lowpass model is not used in the following.
You have to make clear followings.
 - True Baseband Signal
 - Representation of RF Bandpass Signal as Equivalent Baseband Signal
 - Representation of RF Bandpass Signal as True RF Bandpass Signal
About phase noise of RF Bandpass Signal, it is impossible to treat it as "Representation of RF Bandpass Signal as True RF Bandpass Signal".
It might be impossible to treat "s2p" file in "True RF Bandpass Signal" as far as you use the following "RF Blockset".
  RF Blockset>Physical>Input/Output Ports>Input Port
  RF Blockset>Physical>Input/Output Ports>Output Port
  RF Blockset>Physical>Black Box Elements>General Passive Network
Instead, create real coefficients FIR model to express S21 as true RF Bandpass model.
Ptolemy can treat "s2p" in both "Equivalent Baseband Signal" and "True RF Bandpass Signal" seamlessly.
Ptolemy calculate complex coefficietns FIR model for former case and real coefficients FIR model for latter case.
« Last Edit: Nov 4th, 2009, 8:34am by pancho_hideboo »
memomemomemo
Reply #5 - Nov 5th, 2009, 10:27am
Hi Pancho,
I am very confused with the RFBlockset. Should the input to the input port of rfblockset be a baseband signal? In my simulation, I was giving a passband signal to the rfblockset. then After the rfblockset , I was down-mixing it to get the baseband signal.
Would you give an email of yours, so I can send my simulink file to you?
Reply #6 - Nov 8th, 2009, 1:17am
memomemomemo wrote on Nov 5th, 2009, 10:27am:
I'm not kind and patient enough.
You had better expect that other people who is very kind and patient could help you.
