It's still likely to be some glitches in the sub-range flash converter thermometer decode, any error correction block, or the output latches/logic. I'm referring to blocks in Fig 3 of
http://www.commsdesign.com/main/9810/9810feat2.htm, because we still have virtually no information on your design in which to make an informed diagnosis.
I'm sure if you probed around your design, working back from the output, you ought to be able to find where the glitches are coming from. That's far more likely to be successful than expecting people on a forum to diagnose your problem with such a minimal amount of information to go on!
Best Regards (and good luck),
