May 18th, 2024, 2:56am
Active load noise (Read 3071 times)
raja.cedt
Active load noise
Sep 12th, 2009, 6:50am
hi,
   can any body please tell me why active load thermal noise is more than passive resistor noise. From math i got to know that noise  depends on ratio of V and I. But i am expecting some intutive answer.
thanks,
Rajasekhar.
MarcoC
Cesena, Italy
Re: Active load noise
Reply #1 - Sep 14th, 2009, 12:49am
I will try to answer. In a passive resistor there is -approximately- only one physics noise source: the thermal motion of electrons.
In an active load the noise is due to many factors: the thermal motion of electrons in channel, the dangling bounds on the oxide-silicon surface and -in very short channel MOS- we can see also shot noise.
Morover, in active loads the R value is not constant.
This is my own answer to why active loads have more noise then passive loads.
I hope this is clear.
MC
View Profile MarcoC   IP Logged
raja.cedt
Reply #2 - Sep 14th, 2009, 1:21am
hi,
   thanks for your answer..but even if you consider only thermal noise of the channel then also active load is main contributor...you can derive also...
thanks,
rajasekhar.
Mayank
Reply #3 - Sep 14th, 2009, 5:53am
raja.cedt wrote on Sep 12th, 2009, 6:50am:
hi,
thanks,
Rajasekhar.
     An active load is a voltage-dependent resistance which introduces non-linearity effects into the circuit ( Total Harmoic Distortion increases ). also as in one of the replies above, an active device introduces thermal noise whose magnitude is proportional to γ - a parameter that scales based on channel lengths. [ nearly 2/3 for long channel , nearly 1 for short channel ] Also, flicker corners vary with different processes, that also decides the total thermal noise contribution. Accounting for all these factors, total noise from an active load should generally be more than its passive counterpart.
Hope this extends the above post by MarcoC & explains your query,
thanks,
Mayank.
MarcoC
Cesena, Italy
Reply #4 - Sep 14th, 2009, 6:20am
This is a good answer. My post was quite generic.  ::)
Thanks Mayank,  I could not be more exhaustive!
