Oct 21st, 2024, 1:26pm
Diffamp (Read 4489 times)
raja.cedt
Diffamp
Sep 25th, 2009, 9:41am
hi,
  while reading differential amplifiers i found 4 gains (differential to differential, common mode to differential, common mode to common mode,differential to common mode)..i didn't understand theoretically how differential mode will be converted into common mode
Rajasekhar.
cczhang
Re: Diffamp
Reply #1 - Sep 27th, 2009, 2:02am
HI,generally speaking, differential opamp has common mode feedback circuit, and there will be mismatch between mosfets, so there will be four gains
raja.cedt
Re: Diffamp
Reply #2 - Sep 27th, 2009, 8:49am
hi,
   could you please explain clearly..
Rajasekhar.
HdrChopper
Re: Diffamp
Reply #3 - Sep 27th, 2009, 9:07am
Hi Rajasekhar,
Itīs simple: just imagine a resistive loaded diff pair with a purely differential signal, and assume a mismatch on the load resistor.
The single ended output signals will not be perfectly centered around the nominal CM since both are different (non-symmetrical) due to the resistorīs mismatch.
Thus you generated a CM output signal by ONLY applying a differential signal.
Tosei
Keep it simple
raja.cedt
Re: Diffamp
Reply #4 - Sep 28th, 2009, 9:49pm
hi,
   thanks for your ans, i have understand your ans like the following. Due to mismatch in resistor output voltages are not perfect differential, so you can divide them into differential and common mode. Correct me if am wrong.
rajasekhar.
cczhang
Re: Diffamp
Reply #5 - Sep 29th, 2009, 12:26am
raja.cedt wrote on Sep 28th, 2009, 9:49pm:
hi,
rajasekhar.
Hi,maybe this paper will help you understand the gains.
raja.cedt
Re: Diffamp
Reply #6 - Sep 29th, 2009, 1:13am
hi cczhang,
                 thank you very much for the paper.
Rajasekhar
HdrChopper
Re: Diffamp
Reply #7 - Sep 29th, 2009, 7:12pm
hi,
rajasekhar.
That's correct Rajasekhar.
Tosei
Keep it simple
