I would like to simulate the input-referred noise of a SC integrator in SpectreRF:
- My test bench is the same as the circuit depicted in figure 10, on page 12 of (
http://www.designers-guide.org/Analysis/delta-sigma.pdf), where S/H is implemented by ideal circuit elements (ideal switch + cap + buffers) to avoid hidden states)
- I am using the "time-domain" noise feature of spectreRF as suggested by: (
http://www.designers-guide.org/Analysis/sc-filters.pdf) to simulate the discrete-time behavior.
- to calculate the noise power I integrate the spectrum from 0 to fs/2.
My main question is: How is it possible to obtain the "input-referred" noise from this "time-domain" noise simulation, as it only allows to plot (and integrate) the "output" noise? (in Cadence: DirectPlot >> main form >> tdnoise).
Also, I am not sure whether the "input-referred" noise means the noise across the sampling cap or it is just the noise at the input voltage source node to the integrator?
Any help is very much appreciated!
Ali
