May 1st, 2024, 10:23pm
problem in running IC610 (CADENCE) (Read 7825 times)
VINAY RAO
Oct 01st, 2009, 10:04am
Recently i installed IC610 (cadence),but while running "icfb" i am getting many errors.When i give the comand "icfb" ,CIW opens but in between it ask for :"(delicense-7) couldnt get a license for schematics L.would you like to try to get a higherr tiered license to run this product?....(yes)..(no)..(always)..(never).."
By clicking yes,we are getting error..
warnings and errors are,
"*WARNING* (icLic-3) Could not get license Virtuoso_Schematic_Editor_XL
Loading awv.cxt
*WARNING* There were no system .cdsplotinit files found.
Loading NCSU SKILL routines...
Loading oasis.cxt
ERROR (ADE-5066): Tool 'spectreS' has not been registered.
ERROR (ADE-5067): Unable to initialize tool 'spectreS'; either tool class is not
defined or tool is not registered.
*Error* The default SKILL generic function has not been defined for the function "asiEnvGetVar". Ensure that this function is called with the correct argument(s) (tool partition name)
for more details pl checkout the attachment with this..
How can i solve this problem...pl reply soon..
Thank you,
VINAY RAO.
Riad KACED
Swindon, UK
Re: problem in running IC610 (CADENCE)
Reply #1 - Oct 2nd, 2009, 12:23am
I'm doubting spectreS is registered in IC6. This is an old simulator left for legacy reasons in IC5141. Would you mind running the following Skill command into your CIW ?
envGetLoadedTools(  )
Assuming spectreS is not supported in IC6, you need to find in your init files where spectreS is being referenced and get rid of it. You better talk to your PDK provider as I'm not familiar with yours.
BTW, thanks for posting your log file in the original ASCII format that we can all read without needing any tools from that company whose name is not worth to be mentioned in here ...
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
VINAY RAO
Reply #2 - Oct 2nd, 2009, 11:09am
I  did as per u said and it shown follwng tools
("Diva" "UltraSim" "adle" "ams" "asimenv"
   "auCore" "cdba" "ddserv" "designEditor" "graphic"
   "hspiceD" "layout" "layoutXL" "rod" "schematic"
   "spectre" "ui"
And for creating new library,its showing following errors..
*Error* eval: undefined function - libManCreateLib
<<< Stack Trace >>>
libManCreateLib("cdkCreateNewLib" "analogLib" "MOS_a2d" "ams" "" ... )
(... in ddsiLMCEval ...)
(... in ddsLMCMenuItem ...)
ddsLMCMenuItem(1 "cdkCreateNewLib" "libManCreateLib" ("analogLib" "MOS_a2d" "ams" "" "")),,,,,
The above is bcz of any installation problem??
Riad KACED
Swindon, UK
Reply #3 - Oct 5th, 2009, 4:53am
Rather hard for me to answer since it is likely to be tied to your PDK.
Would you mind doing something for me please.
In your library manager, right click that NCSU library and get it's read/write path. Browse to that path from your UNIX terminal and look at a file called libInit.il. Edit this file and comment any line that mentions spectreS. Acoording to what you have posted, spectreS is definitely not supported and one need to clean any calls to that simulator.
So if you are able to comment 'spectreS' in the NCSU library, then restart your Cadence session and things should be alright.
Best for you is to get in touch with your PDK provider though. You need to make sure using the right PDK with the right Cadence tools.
Cheers,
Riad.
Riad KACED
