Jul 23rd, 2024, 4:30am
HDL FILTER DESIGN WITH MATLAB (Read 2025 times)
silverit
Oct 08th, 2009, 1:02am
I want create a lowpass FIR FILTER with the followin spec.:
Fs=400MHz Fpass=55MHz Fstop=150MHz Apass=1 Astop=150
I have quantize the filter with 14bit in/out.
I have a doubt regarding "Filter Internals" when select the
"Rounding Mode" and "Overflow Mode". Is there a best setup for this parameter?
rampat
Re: HDL FILTER DESIGN WITH MATLAB
Reply #1 - Nov 10th, 2009, 9:34pm
Hi
you need to compare how many adders and delay elements needed for each case,then you have to choose among them which gives you least
Ramesh
View Profile rampat   IP Logged
