May 11th, 2024, 2:45pm
how to set the vale of output frequency sweep range in pnoise simulation (Read 6178 times)
bsaqycx
Asia
Nov 03rd, 2009, 2:55am
Dear all:
       I'd like to simulate the jitter of clock slicer ( used to adjust the duty cycle of clock ). When I do the pnoise simulation, I've no idea how to set  the vale of output frequency sweep range. When I set the " stop" value to be 2 times clock frequency ( 8MHz) , the outcome seems reasonable ( 5ps ). But when I set the " stop" value to be 1GHz, the jitter turns to be 6us. I've no idea how to choose output frequency sweep range correctly.
      What's more, when I open " Main Form" I find an option called "tdnoise". What's the meaning of this result?
      Thank you in advance!
Frank Wiedmann
Munich, Germany
Re: how to set the vale of output frequency sweep range in pnoise simulation
Reply #1 - Nov 3rd, 2009, 5:32am
See http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785 and the links given there (http://www.designers-guide.org/Forum/YaBB.pl?num=1092399689/20#20 for the frequency range in tdnoise or jitter analysis).
bsaqycx
Asia
Reply #2 - Nov 3rd, 2009, 7:27pm
Thank you very much for your help!
bsaqycx
Asia
Reply #3 - Nov 10th, 2009, 10:46pm
the frequency of input clock is 4MHz, how should I choose the Stop frequency to get the proper cycle-to-cycle jitter? The results change a lot if the Stop frequency is chose different!
Haward Zhu
Reply #4 - Sep 19th, 2010, 11:46pm
the same question confused me too
