Apr 28th, 2024, 11:22pm
noise analysis (Read 2370 times)
nobody
noise analysis
Dec 28th, 2009, 3:01am
Hello, all
I have a question about how to do the noise simulation of a "flip-around" SHA in the hold phase. To be more precisely, I question the total output noise @ the hold phase because the magnitude of noise is much larger than expected. If I hook up the circuit like Fig.1 called " charge transferred SHA" ,typically gain= cs/cf=2, the magnitude of output noise looks good. Fig.2 shows the way I did the simulation. An ideal cmfb is added and ideal baluns are used to convert differential and common signals.
Thanks a lot.
*** spice deck ***
vic vic 0 1
vid vid 0 ac
.ac dec 100 1e3 100e9
.noise v(vod) vid
Re: noise analysis
Reply #1 - Dec 28th, 2009, 8:50am
Look at http://www.designers-guide.org/Analysis/sc-filters.pdf for an explanation of how to perform noise analysis of a sample and hold amplifier (SHA).
