Hi Mayank,
You wrote :-
Quote: author=Mayank_Singh link=1264764783/0#12 try converging simultaneously wheile it's running tstab).
I don't understand this either. PSS does not converge (shooting method) until the tstab initial stabilization transient run is complete. Quote: 2 doubts :--- 1> When BDA generates the psfbin output, it generates period jitter, period jitter_flicker, and period jitter_white under the pnoise-SummaryStatistics.Pnoise section. May i know what formula does bdasim use to compute these values ???
Please contact me directly and we can discuss.
I suggest that you use nutbin output format when running PSS/PNoise. If you do this then you will get separate plots of phase noise (white) and phase noise (white + flicker). These outputs are not available in psfbin format. Use BDA's Wavecrave waveform tool to view BDA's nutbin format.
Quote: 2> Do the PPV values under the section pnoise-NoiseSourceIntensityNoiseSensitivityandProduct.pnoise indicate ISFs [ impulse sensitivity functions ] at these nodes ??
Yes, they do.
Michael
