Aug 16th, 2024, 1:12pm
verilog A code for 16:1 mux (Read 18059 times)
bal
Feb 14th, 2010, 2:26pm
i need a verilog A code for 16:1 mux ..thank you
Re: verilog A code for 16:1 mux
Reply #1 - Feb 15th, 2010, 2:00am
http://www.designers-guide.org/Forum/YaBB.pl?num=1260351750/5#5
If you have Cadence Spectre, see "ahdlLib/multiplexer".
You can easily modify this code to create 16:1 Mux. Here use "case ~ endcase" statement in Verilog-A code.
bal
Reply #2 - Feb 15th, 2010, 4:13am
since its a 16:1 i have 4 select pins which i have declared it is as input pins .. so these ports cannot be used for binary to decimal conversion in further logic .. As u told ,a case statement should be used , but before using that i need find a way such that i must covert all 4 bits to decimal value store in a variable and use it in a case statement. If u could tell me a logic for above problem i can use the case statement and select the inputs . thank you..
Reply #3 - Feb 15th, 2010, 4:20am
There are many methods to use binary expression for case statement.
For example, see http://www.designers-guide.org/Forum/YaBB.pl?num=1265985977
`define  Nbits     4
input [`Nbits-1:0] sel;
voltage [`Nbits-1:0] sel;
parameter real Vth=1.5;
integer logic_value[0:`Nbits-1];
integer sel_value;
genvar i;
analog begin
sel_value = 0;
for(i=0; i <=`Nbits-1; i=i+1) begin
    logic_value[i] = (V(sel[i]) > Vth) ? 1 : 0;
    sel_value = sel_value + logic_value[i]*(1<<i);
case(sel_value)
endcase
Read documents of Verilog-A surely.
Attached is an example for conventional usage of case statement.
« Last Edit: Feb 16th, 2010, 2:54am by pancho_hideboo »
Reply #4 - Feb 15th, 2010, 4:35am
Attached is another example for usage of binary data in case statement.
( (logic_value[3]==1) && (logic_value[2]==1) && (logic_value[1]==0) && (logic_value[0]==1) ) : "statement";
