May 13th, 2024, 11:15pm
Pages: 1 2 3
How to plot "input reflection coefficient" in ADS (Read 956 times)
Re: How to plot "input reflection coefficient" in ADS
Reply #15 - Feb 24th, 2010, 7:10am
DoYouLinux wrote on Feb 24th, 2010, 7:06am:
However, is Gamma_L still the same:
Gamma_L=(ZL-conj(Z02))/(ZL+Z02)
pancho_hideboo wrote on Feb 17th, 2010, 3:17am:
Of course, you can also calculate Gamma_in by the following.
Gamma_in=S(1,1)+S(1,2)*S(2,1)*Gamma_L/(1-S(2,2)*Gamma_L)
Gamma_L might be (ZL-Z02)/(ZL+conj(Z02)) in the above.
But I use AC analysis for evaluation of Γin. I don't use SP analysis.
So I have not confirmed this for complex reference impedance case.
I use custom interstage impedance probe with conventional AC analysis and master large signal steady state analysis followed by small signal AC analysis.
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1221012939
http://www.designers-guide.org/Forum/YaBB.pl?num=1240334878/18#18
http://www.designers-guide.org/Forum/YaBB.pl?num=1218635777/5#5
Also see http://www.edaboard.com/viewtopic.php?t=380636
Again see the following. This is also interstage impedance probe, although this gives reflection coefficients not impedances.
pancho_hideboo wrote on Feb 17th, 2010, 7:30am:
In Agilent ADS, "SP_Probe" is available for evaluation of Zs,Zin,Zout and ZL.
http://edocs.soco.agilent.com/display/ads2009/SP+Probe+%28S-Parameter+Probe%29
Back to original topics of this thread.
ΓP=(Zin-conj(Z01))/(Zin+Z01)
ΓV=(Zin-Z01)/(Zin+Z01)
If Z01 is real number, ΓPV.
Is Z01 real number in your evaluation of Γin ?
If Z01 is complex number, which type of reflection coefficient is required as Γin, ΓP or ΓV.
When Z01 is complex number, results of SP analysis are all  ΓP type not ΓV type.
I think the followings are proper in sqrt(Power) wave formulation, although I have not confirmed.
ΓS=(ZS-Z01)/(ZS+conj(Z01))
Γin=(Zin-conj(Z01))/(Zin+Z01)
Γout=(Zout-conj(Z02))/(Zout+Z02)
ΓL=(ZL-Z02)/(ZL+conj(Z02))
« Last Edit: Feb 24th, 2010, 9:27am by pancho_hideboo »
Reply #16 - Feb 25th, 2010, 3:54am
pancho_hideboo wrote on Feb 24th, 2010, 7:10am:
I confirmed this.
Gamma_L has to be (ZL-Z02)/(ZL+conj(Z02)).
Attached figure is a testbench schematic for AC analysis.
The followings are netlists of DUT. Here I used netlist of Cadence Spectre syntax directly in Agilent ADSsim.
"FBP_1.scs": Code:
simulator lang=spectre
global 0
include "~/RFDE/FBP_1.sub"
I1 (in out) bpf
"FBP_1.sub": Code:
// Star-Hspice Manual, Release 1998.2 at page.9-21
// Bandpass Netlist: Star-Hspice Network Analysis Results
// References
// Goyal, Ravender. "S-Parameter Output From SPICE Program", MSN & CT,
// February 1988, pp. 63 and 66.
// FILE: FBP_1.SP
// BAND PASS FILTER
subckt bpf ( in out )
c1 ( in 2 ) capacitor c=3.166p
l1 ( 2 3 ) inductor l=203n
c2 ( 3 0 ) capacitor c=3.76p
c3 ( 3 4 ) capacitor c=1.75p
c4 ( 4 0 ) capacitor c=9.1p
l2 ( 4 0 ) inductor l=36.81n
c5 ( 4 5 ) capacitor c=1.07p
c6 ( 5 0 ) capacitor c=3.13p
l3 ( 5 6 ) inductor l=233.17n
c7 ( 6 7 ) capacitor c=5.92p
c8 ( 7 0 ) capacitor c=4.51p
c9 ( 7 8 ) capacitor c=1.568p
c10 ( 8 0 ) capacitor c=8.866p
l4 ( 8 0 ) inductor l=35.71n
c11 ( 8 9 ) capacitor c=2.06p
c12 ( 9 0 ) capacitor c=4.3p
l5 ( 9 10 ) inductor l=200.97n
c13 ( 10 out ) capacitor c=2.97p
ends bpf
Reply #17 - Feb 25th, 2010, 4:15am
Attached figure is a testbench schematic for SP analysis.
Reply #18 - Feb 25th, 2010, 4:19am
Attached figure is a result.
Reply #19 - Feb 25th, 2010, 4:20am
Attached figure is a result as "pdf" format for detail view.
DoYouLinux
Reply #20 - Apr 21st, 2010, 8:35pm
Hi pancho_hideboo,
Thank you very much again for your great post. I am trying to understand the given example. One thing that is still not clear to me is Gamma_L, why is it defined as "Gamma_L=(ZL-Z02)/(ZL+conj(Z02))" ??
Should it be defined as "Gamma_L=(ZL-conj(Z02))/(ZL+Z02)" ??
Thank you very much,
DYL
Reply #21 - Apr 22nd, 2010, 10:08am
DoYouLinux wrote on Apr 21st, 2010, 8:35pm:
Should it be defined as "Gamma_L=(ZL-conj(Z02))(ZL+Z02)" ??
No.
It has to be Gamma_L=(ZL-Z02)/(ZL+conj(Z02)).
See equations in http://www.designers-guide.org/Forum/Attachments/test_FBP_1.pdf
Derive Gamma_out and Gamma_L from definition in http://en.wikipedia.org/wiki/S-parameters.
As direct thought, simply consider "complex conjugate matching condition" as reflection coefficient expressions, Gamma_out and Gamma_L.
« Last Edit: Apr 23rd, 2010, 2:27am by pancho_hideboo »
DoYouLinux
Reply #22 - May 6th, 2010, 8:01am
Hi pancho_hideboo,
Thank you very much for the explanation, again. Let me take some time to prove and understand them.
However, as I tried to follow the given example to plot Gamma_in (the BPF example), but here I used a transistor as a test vehicle. I found from the result that, in the plot of Gamma_in using "stos" function, if I defined the function as:
S_new=stos(S, PortZ, {Zo1, Zload}),
then S_new(1,1) will be identical to Gamma_in I defined using an equation. However, if I replaced Zo1 in the S_new function by Zsource as:
S_new=stos(S, PortZ, {Zsource, Zload}),
then S_new(1,1) will not be identical to Gamma_in function. How come ?
To my understanding "S_new=stos(S, PortZ, {Zsource, Zload})" should be correct because we changed the reference impedance to be Zsource and Zload (here in my case, my Zo1 is not equal to Zsource, as in your example).
Could you clarify more on this point, please ?
Thank you very much in advance,
DYL
DoYouLinux
Reply #23 - May 6th, 2010, 8:02am
Here is the result:
Reply #24 - May 6th, 2010, 8:16am
Gamma_in is not correct for your case since you change Z01.
On the other hand, S_new(1,1) is correct.
Equation for Gamma_in has to be modified if Z01 is changed.
You can derive modified equation for Gamma_in_corrected valid for changing Z01.
Calculate Zin from Gamma_in=(Zin-conj(Z01))/(Zin+Z01).
Next calculate Gamma_in_corrected as (Zin-conj(Zs))/(Zin+Zs).
« Last Edit: May 7th, 2010, 12:57am by pancho_hideboo »
DoYouLinux
Reply #25 - May 8th, 2010, 10:39am
Hi pancho_hideboo,
Thank you for your further explanation. However, I think that I am still confused about the expression "S_new" using "stos" function of ADS.
As explained also in the attached figure, to my understanding, the "PortZ" argument represents the default set of reference impedances, which are Zo1 and Zo2 as shown in the schematic. In my example, Zo1 and Zo2 imply the reference impedances used for characterizing the default S parameters of the transistor.
Then, the transistor was assume to be terminated with another set of impedances at the source side and the load side, which are "Zsource" and "Zload" in this example. This new termination is defined in the "S_new" expression as "{Zsource, Zload}". So, "Zsource" will be a new termination for port 1 (source side) and "Zload" will be a new termination for port 2 (load side).
Then, I compared "S_new(1,1)" with the "Gamma_in" expression given in the previous reply. The "Gamma_in" expression uses "my_Sxx" to represent the default set of  S parameter based on Zo1 and Zo2 reference impedances. "Gamma_L" in "Gamma_in" expression represents the load reflection coefficient due to termination using "Zload".
From my understanding described above, I expected that "S_new(1,1)" and "Gamma_in" would be identical. But this was not the case. However, when I changed the new reference impedance in the "stos" function of the "S_new" expression to be "{Zo1, Zload}", the expressions "S_new" and "Gamma_in" were identical. Why when I replaced "Zsource" with "Zo1", the results were identical ?
"Zo1" is not a new reference impedance at the source side (it is the default reference impedance at the source side instead), in my understanding, "Zsource" should be the correct variable.
Would you mind to explain me further about this please ? I really want to understand as clear as I can.
Thank you very much again,
DYL
Reply #26 - May 8th, 2010, 10:46am
I can't understand what you want to mean at all.
"stos()" is very clear and straightforward.
If you have any doubt about it, see its definition in "$HPEESOF_DIR/expressions/ael/network_fun.ael".
PortZ={Z01, Z02}
Zs!=Z01, ZL!=Z02
S_Z01_ZL=stos(S, PortZ, {Z01, ZL})
S_Z01_ZL(1,1)==Gamma_in
S_Zs_ZL=stos(S, PortZ, {Zs, ZL})
S_Zs_ZL(1,1)!=Gamma_in
S_Zs_ZL(1,1)==Gamma_in_corrected
Zin is unique regardless of {Z01,Z02} values.
Zin is determined by only ZL.
Gamma_in is a reflection coefficient defined for Zin and Z01.
Gamma_in_corrected is a reflection coefficient defined for Zin and Zs.
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1266403928/24#24
Try to calculate Gamma_in_corrected.
Show me plot result of this Gamma_in_corrected and S_new(1,1).
I think you can't understand S-parameters and Reference impedances at all.
I think you should not use S-parameter formulation.
You had better use AC analysis, although there are no difference between AC and SP analyses for me,
since they are both linear analysis.
« Last Edit: May 8th, 2010, 2:10pm by pancho_hideboo »
DoYouLinux
Reply #27 - May 10th, 2010, 9:21am
Hi pancho_hideboo,
Thank you very much again for your explanation. I really appreciated it. I think perhaps I am confused about the definition of the "input reflection coefficient" and also confused about the expression of "stos" function. Therefore, I tried to summarize again in the attached figure.
In the figure, what I understood is, please correct me if I were wrong,:
1) A 2-port was first characterized with reference impedances Zo1 and Zo2. From these reference impedance, the default S parameter set was obtained and the input reflection is S11. The reference impedance is defined as "portZ" in the "stos" function.
2) Then, assuming that the reference impedance on the load side was changed to "Zload", now the input reflection coefficient was not equal to S11 anymore (since Gamma_L is not zero). In this configuration, the new reference impedance was defined as "{Zo1, Zload}" in the "stos" function (Zo1 remains but Zo2 replaced by Zload). Then, "Gamma_in" can be found from S_new(1,1).
Did I understand correctly ?
Thank you in advance again,
DYL  :)
Reply #28 - May 10th, 2010, 9:24am
DoYouLinux wrote on May 10th, 2010, 9:21am:
Correct
DoYouLinux
Reply #29 - May 27th, 2010, 6:43am
Hi Pancho_Hideboo,
After I repeat the simulation in ADS again, I got correct results. Thank you very much again for your explanation about Gamma_in topic.
DYL
Pages: 1 2 3
