Jul 2nd, 2025, 6:40am
Switched Capacitor, pss and pac (Read 2292 times)
computaholic
Mar 04th, 2010, 1:50am
Hello everyone,
I am trying to simulate the frequency response of a very simple sc circiut. But i guess i am not able to generate any useful results, as a matter of fact, i (almost) dont have any idea how to do that. I have read a lot and i know it is somehow possible with pss and pac. But i just cant get these simulations up running. Maybe theres someone who can help me.
Here some facts about my workspace:
Tool: Cadence Virtuoso ADE L using Spectre
The attached file includes all screenshots i took.
"sc_sch" shows the circiut. Its supposed to be a low pass using sc. As the input source I chose "vsource" with "type dc" and "pacmag 1V". Nothing else is set.
PHI and PHIbar are "vsource" with "type pulse". The options taken can be seen in the screenshots.
Well, after doing everything as seen on the screenshots, I run pss and pac but all i get is an empty graph titeling "AC Response", but there's nothing to see.
Can Anybody help me with this?
computaholic
Re: Switched Capacitor, pss and pac
Reply #1 - Mar 4th, 2010, 2:06am
Your circuit is a simple parallel SC same as attached figure.
Show me your netlist.
computaholic wrote on Mar 4th, 2010, 1:50am:
BTW, why do you plot "AC Response" not "PAC Response" ?
Reply #2 - Mar 4th, 2010, 2:21am
Netlist for "Tran_Impulse" Quote:
// Generated for: spectre
// Generated on: Apr 23 21:13:18 2001
// Design library name: MyTestLib
// Design cell name: Parallel_SCF
simulator lang=spectre
global 0
parameters tw_in=1u tw=3u tr_in=0.05u tf_in=0.05u tf=0.05u dv=1e-3 VL=-0.5 \
   VH=0.5 tr=0.05u tperiod=12.5u td1=1u k=2 \
   td_in=(td1+tr+tw)-(tr_in+tw_in/2) td2=td1+(tperiod-k*(tr+tw+tf))
// Library name: MyTestLib
// Cell name: Parallel_SCF
// View name: schematic
Vimpulse1 (Vin 0) vsource dc=5 type=pulse delay=td_in val0=0 val1=1 \
       period=1K rise=tr_in fall=tf_in width=tw_in pacmag=1
Vimpulse2 (net22 0 Vin 0) vcvs gain=1
R1 (Vct_out net22) resistor r=25K
SW1 (Vin Vmid phi1 0) relay vt1=(VL+VH)/2-(dv) vt2=(VL+VH)/2+(dv) \
       ropen=10M rclosed=10m
SW2 (Vmid Vsc_out phi2 0) relay vt1=(VL+VH)/2-(dv) vt2=(VL+VH)/2+(dv) \
Phai_2 (phi2 0) vsource type=pulse val0=VL val1=VH period=tperiod \
       delay=td2 rise=tr fall=tf width=tw fundname="Phai_2"
Phai_1 (phi1 0) vsource type=pulse val0=VL val1=VH period=tperiod \
       delay=td1 rise=tr fall=tf width=tw fundname="Phai_1"
C2 (Vct_out 0) capacitor c=1n
C6 (Vsc_out 0) capacitor c=1n
C3 (Vmid 0) capacitor c=500.0p
   digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
   sensfile="../psf/sens.output"
tran tran stop=4.096m maxstep=0.05u write="spectre.ic" \
   writefinal="spectre.fc" annotate=status maxiters=5
finalTimeOP info what=oppoint where=rawfile
save phi1 phi2 Vin Vmid Vsc_out Vct_out
saveOptions options save=selected
Attached figure is "Time Domain Waveforms" for Transient Analysis.
Reply #3 - Mar 4th, 2010, 2:22am
Netlist for "PSS_PAC" Quote:
// Generated on: Apr 23 21:16:27 2001
global 0
Vimpulse1 (Vin 0) vsource dc=5 type=dc delay=td_in val0=0 val1=1 period=1K \
pss  pss  period=12.5u  harms=0  maxacfreq=1M  annotate=status
pac  pac  sweeptype=absolute  start=10  stop=40k  maxsideband=2
+    annotate=status  freqaxis=absout
save Vsc_out Vct_out
Attached figure is "Frequency Responses".
computaholic
Reply #4 - Mar 4th, 2010, 3:05am
Ok, here is my netlist:
[ Quote:
// Generated on: Mar  4 10:39:24 2010
// Design library name: neuro_opamp_lib
// Design cell name: sc_lowpass_tb_01
global 0
parameters Ibias=-1u rcut=1M ccut=1p Vdd=3.3 Csc=25f Clp=20p frq=640k \
   PulseCut=10n inputfrq=100
include "/usr/prog/lfoundry/LF150/V1.2.0/PDK_LF150C_V1_2_0/models/spectre/LF150_Spectre.
scs" section=MOS_tt
scs" section=act_t
scs" section=pas_t
scs" section=fix
// Library name: neuro_opamp_lib
// Cell name: sc_lowpass_tb_01
C_Csc (net046 0) capacitor c=Csc
C_Clp (pVout 0) capacitor c=Clp
M0 (net046 lPHI lVin lVin) nmos_3 w=7.5u l=400.0n as=(3.375e-12)/(1) \
       ad=(3.375e-12)/(1) ps=(15.9u)/(1) pd=(15.9u)/(1) m=(1)*(1)
M1 (pVout lPHI_BAR net046 net046) nmos_3 w=7.5u l=400.0n \
       as=(3.375e-12)/(1) ad=(3.375e-12)/(1) ps=(15.9u)/(1) \
M2 (net046 lPHI_BAR lVin lVin) pmos_3 w=18u l=400.0n as=(8.1e-12)/(1) \
       ad=(8.1e-12)/(1) ps=(36.9u)/(1) pd=(36.9u)/(1) m=(1)*(1)
M3 (pVout lPHI net046 net046) pmos_3 w=18u l=400.0n as=(8.1e-12)/(1) \
V3 (lVin 0) vsource dc=Vdd/2 type=dc pacmag=1 phase=1
PHI_BAR (lPHI_BAR 0) vsource type=pulse delay=(1/(2*frq)) val0=0 val1=3.3 \
       period=1/frq rise=2n fall=2n width=(1/(2*frq)) - PulseCut
PHI (lPHI 0) vsource type=pulse val0=0 val1=3.3 period=1/frq rise=2n \
   checklimitdest=psf
pss  pss  fund=640K  harms=0  errpreset=liberal  tstab=1.5m
+    saveinit=yes  maxacfreq=50M  tstabenvlp=no
pac  pac  start=1  stop=50M  dec=1  maxsideband=1  annotate=status
save lVin pVout
If Im displaying AC instead of PAC, how can I display PAC? The AC Response window just pops up automatically.
Reply #5 - Mar 4th, 2010, 3:08am
computaholic wrote on Mar 4th, 2010, 3:05am:
It seems simply you can't understand plotting in Cadence ADE.
Use "Direct Plot Form" in Cadence ADE.
computaholic
Reply #6 - Mar 4th, 2010, 3:58am
All Right! The Direct Plot Main Form did the work. I guess there were actually no mistakes, but i had trouble plotting it.
Another questions has come up: What does the sidebands option do?
Reply #7 - Mar 4th, 2010, 4:15am
computaholic wrote on Mar 4th, 2010, 3:58am:
Enter "spectre -h pac" in unix command line.
Then read its messages.
For your case, sideband which you should look is zero.
