Dec 17th, 2025, 12:45am
spectreRF pstb simulation with multi-loop circuit (Read 7277 times)
rfmems
Mar 12th, 2010, 1:22am
Description of the circuit
1, LDO+push pull VCO
2, LDO output biases VCO, inductor center tap feedbacks to LDO inputA, inputB is reference voltage
3, LDO: differential current mirror load amp.+miller compensated pmos
Objective
To simulate the LDO stability when the VCO is running in steady state.
Problem
The circuit is mulit-loop, LDO feedback, miller compensation. There is no way to cut all the loops at once. So I put the probe at LDO feedback path (from inductor center tap to LDO inputA). But I got strange results from simulation. Simulated gain drops to 0dB from DC to 100Hz, and then slowly increases to peak 40dB at 50KHz. Phase margin also started from 0 at DC and increases to 90 at 50KHz.
Comparing dc/tran+stb VS. pss/pstb, the simulation results are similar when freq>100KHz, but below that, pss+pstb makes no sense to me.
Question
1, I guess multi-loop circuit stability simulation is out of pstb's capbility, but did anyone have luck with that issue?
2, If it is not possible to simulate with pstb, is there a solution to this kind of stability simulation?
Re: spectreRF pstb simulation with multi-loop circuit
Reply #1 - Mar 12th, 2010, 2:30am
rfmems wrote on Mar 12th, 2010, 1:22am:
Use "Periodic Steady State (Harmonic Balance) Based Stability Analysis" of Agilent GoldenGate.
http://www.designers-guide.org/Forum/YaBB.pl?num=1243078889
http://www.home.agilent.com/agilent/product.jspx?cc=JP&lc=jpn&ckey=1738199&nid=-...
rfmems
Reply #2 - Mar 12th, 2010, 2:57am
Thank you very mucn pancho for your response.
Your comments on 'Stability of Total Circuits' certainly are interesting and enlighten.
However, my circuit, LDO+VCO, in its nature is instable since it oscillates. And what I try to figure out is whether the LDO feeback loop is stable. In another word, I am looking for instabilities of my circuits except the oscillator itself. I suppose that is where spectre has problem with.
Having looked at intriduction of Goldengate, I found it really attractive specially it is fully integrated into cadence ADE. Sadly, most engineers have to live with the simulators provided to them, which in my case, don't include Goldegate.
Reply #3 - Mar 12th, 2010, 3:00am
rfmems wrote on Mar 12th, 2010, 2:57am:
In another word, I am tring to figure out instability of my circuits except the oscillator itself.
All eigenvalues are listed in Agilent GoldenGate.
So you can distinguish undesired oscillations(eigenvalues) from desired oscillations(eigenvalues).
http://cp.literature.agilent.com/litweb/pdf/5989-9448EN.pdf
This nonlinear stability analysis was introduced in Xpedion day.
But it was deleted from GoldenGate when Agilent purchased Xpedion.
It has been reimplemented in GoldenGate 4.4.0.
« Last Edit: Mar 12th, 2010, 5:21am by pancho_hideboo »
