Jul 19th, 2024, 8:29am
spectreVerilog simulation problem (Read 4630 times)
jsun
Apr 03rd, 2010, 1:13pm
Hi there,
I am designing ADC. And I have analog part and digital part, so I used spectreVerilog for simulation. Now I met a weird scenario.
I synthesized verilog code by dc and imported it into cadence. Before that, I simulated synthesized verilog code in modelsim and it works properly. However, I put this same code in cadence and run spectreverilog, it only runs for first 10 clk cycles and then all the signals become stable, no more change. It should not be like that. I cannot figure out what's wrong.
Any help?
Thanks...
JSun
Re: spectreVerilog simulation problem
Reply #1 - Apr 7th, 2010, 7:02am
Bear in mind that if using spectreVerilog, you are using VerilogXL, which is a very, very old flavour of Verilog.
Apart from that, it's virtually impossible to help you. Could be anything and with nothing to go on, I'd have to be psychic to be able to know what the problem was!
