Aug 15th, 2024, 12:32pm
nmos varactor degrade phase noise (Read 4750 times)
supermoment
Apr 21st, 2010, 4:06am
I try to design a typical cmos LC VCO. I found out the phase noise degrades a lot after adding nmos varactor as compared to ideal cap.
The phase noise could be improve if add a bypass capacitor (for ac ground) however it will add additional load to the LC tank results in narrow tuning range. Is it common to do so in real practice??
I try to improve it by adding more fingers of nmos varactors. It helps a bit only.
Is there any way to improve the varactor?
rfcooltools.com
Re: nmos varactor degrade phase noise
Reply #1 - Apr 22nd, 2010, 11:23am
The common way is to switch in MIM caps to make bands within a VCO where the varactor will only be used cover the a smaller freq range temperature and process drift to connect the bands.  to make a switch pick the appropriate size NMOS device to minimize off capacitance and minimize on resistance.   Typically VCO's on chip use 4 bits or more of binary weighted MIM capacitors and switches to improve the frequency coverage while off loading varactor tuning.
of coarse this means that tuning requires a state machine or look up table.
love_analog
Reply #2 - Apr 22nd, 2010, 4:19pm
Remember a non-linear varactor will convert the 1/f noise of tail current source to Phase modulation. If you had a perfectly linear cap then you will not see this increase in noise.
loveanalog.blogspot.com
The Power of Analog
supermoment
Reply #3 - May 4th, 2010, 7:15pm
any other ways to improve phase noise besides using more varactor fingers?
love_analog
Reply #4 - May 5th, 2010, 12:35pm
put a ac coupling cap between varactor and output. Will make overall cap more linear.
The Power of Analog
supermoment
Reply #5 - May 5th, 2010, 5:58pm
anyway, i will put programmable cap for coarse tuning. It also works as ac coupling cap Smiley
thank you
love_analog
Reply #6 - May 14th, 2010, 4:12pm
typically the coarse tuning cap will not be in series with the varactor. more like parallel.
would be curious to see your schematic.
The Power of Analog
